God damn $%@"!
Ceirwan
Yeah, having a little trouble removing the cover to get at my clocks, ive taken out the two screws in the top of it, and the one to the right of the ignition.
But it just won't bloody come off, it pulls away a bit, but then it tries to pull away the the gray plastic dome thingy that goes behind the clocks.
The haynes manual isn't being to helpful...
Can anyone on here solve this problem?
dunno about the K11 but the k10 is clipped in, I just give it a hard yank til it rips off, my clips are now broke though so it's up to you lol.
Are you sure those are all the screws there are...?
Its alright for you to say 'rag it off' you were breaking yours for spares! :)
Is that the one just hidden sort over and to the left of the column? Because even with the wheel fully lowered, (well it only moves by about 10cm up and down anyway) i can't get a screwdriver in there...
thats the one, have you not got a tilt steering wheel ?
right, I've just re read your post, you have to remove the column cowling to get to the last screw.
Is that an oh crap i've just set off the airbag job?
Disconnect the battery and leave for a while?
It does tilt, just not much. (when i loosen of the tilty lever underneath!)
no, the cowlimg will just screw off with four screws i think from underneath. deeffinately wont even affect air bag
