Hi I am new to the forum so appologies for asking for help in my first post but as always you find forums when you have a problem.
It is my sisters car and it seems to be sticking in gear almost as if you are trying to change gear without depressing the clutch. I think the clutch on the K12 is hydralic as if you pump the clutch the gear seems to change fine. I have had a look under the bonnet but I could not see a reservoir for clutch fluid (might be shared with break fluid). Any advice would be greatly apperciated.
the car is a 05 1.0 micra manual 5 speed
Sully
Sully
