Just seeing if there is any interest in these and how much i would be likely to get for them.
Set of 2 x Internally shortened Koni adjustable Shocks (shortened to suit the whiteline springs) FRONTS
Set of 2 x Internally shortened Koni adjustable Shocks (shortened to suit the whiteline springs) REARS
Set of 2 x Whiteline -42mm springs FRONTS
Set of 2 x Whiteline -40mm Springs REARS
These are a fantastic suspension setup,
On the softest setting you will have a smoother than std ride and still with much increased grip and stability.
On the hardest setting you will have a very firm track ready ride with outstanding grip in the corners and still good bump absorption.
On a medium setting you will have the best of both worlds, fairly smooth ride and will kill most in the corners but without being uncomfortable.
If you would be interested then please let me know a ball park figure that you would be willing to pay. I WILL be selling as a kit only, as its all designed to go together it would be a waste to split the set.
May also be selling a camber kit if anyone is interested…Another awesome suspension modification.
It will completely eradicate understeer if set up correctly with a firm rear suspension setup!
Pics...
Pics...
