You could take the main pressure line from the tank that runs to the fuel filter, disconnect it, then once the ignition is turned you can run it off into a bucket not sure how long that would take on a full tank though!
the pump only runs for 5 secs if you dont run the engine also tho eh.
what sort of contaminate ?
if it was contaminated with diesel it would be smoking and hard to start eh.Unsure
well im draining it out today so ill keep it for nowif it was contaminated with diesel it would be smoking and hard to start eh.
and unless anyone else complains they will just deny responsibility
it just strange that it only happened after i put the fuel in itIf you actually intend to do anything about it then keep a sample and complain to local trading standards. Chances are though its far more likely that your car is at fault than the fuel is.
