Hello everyone.
I have 2001 1.0 Micra (coilpack) for 15 years, strong runner with no problems until recently. I parked it two days ago and suddenly it will not work now. I traced it down to fuel pump not receiving power.
When I turn ignition to ON position there is 0 volt at the fuel pump plug. My guess is there should be 12 (or so). Obviously there is no noise from pump building pressure. When I try to start the engine it shows about 9 volts there, but it still does not pump (the battery is ok, shows 12,7 volts)
When I connect the pump directly to 12 volts supply it works fine, you can hear it and it pumps fuel (engine starts).
I checked the fuel pump fuse - it is ok.
I suspected the relay, so I swapped it with one from the engine compartment (fan relay), but to no avail.
I removed the fuel pump fuse and measured voltage in the fuse socket. There is about 5 V when the ignition is in ON position, and about 10 V when it is at START position.
I have run out of ideas. Is it some short circuit somewhere? Or is ECU broken?
Please help.
Please help.
