pjg1979
THIS IS MY BOOMSTICK!
I have for sale a Diagnostic & Tune-Up Engine Analyser with original box, as far as I'm aware it's never been used, once again I have aquired this from my father who was having a clearout, I don't have a use for this.
The Anaylser has 5 settings: Point, Volt, Amp, Dwell & Tach.
Box description: This compact size instrument is of high quality and reliability. Will give accurate and precise readings to assist in high performance tuning.
Performs all electrically based tune-ups and test functions for 4, 6 & 8 cylinder engines with operation on 6 or 12 volt positive or negative ground systems.
4 cylinder reading obtained by multiplying 8 cylinder reading by 2 (4 cyl. = 8 cyl. . 2)
Performs most electrical functions for major tune-up.
Measures RPM of 4,6 & 8 cylinder engines at idle speeds.
Indicates cam dwell angle in degrees
Monitors "Good" or "Bad" condition points.
Measures Voltage & Amp current conditions generated in charging system.
Willl Assist in achieving smooth, positive engine performance with peak economy.
Come with a manual as well.
Thanks for looking
Thanks for looking
