fitting super s bumper
joelh
hello i am fitting a front super s bumper to my 1996 k11 1.0 car but i cant find and wiring for um is there supposed to be any? and how do get headlights off with out snaping the bolt holder thing in plastic?
take off the grill matey, there are some square clip things that you have to undo with a flat blade (hidden under the grill) push the grill up from under the head light and you should see, theres loads hidden under there. also there are bolts behind the haedlights (2) and one at the top. 10mm iirc. theres a front bumper removal guide that swiper did in the guides section if thats any use/help to you?
do you mean wiring for the driving lights on the ss bumper? if so i dont think there is any.
hope this helps...
i think the model you have wont support driving lamps,
only the 1.3 loom came with driving lamp support.
the plug is taped up out of the way on the driver's side, and you need a relay to go in the driving lamp section. also you will need another plug for the other side too
