K kyle Sep 24, 2008 #1 Are figaro callipers the same as k10 ones? Do k11 callipers need modification to fit a k10? would k11 callipers give a noticable improvement?
joesouthgate Super Moderator Moderator Club Member Sep 24, 2008 #2 you would need k11 hubs iirc to fit the calipers. see this thread http://www.micra.org.uk/showthread.php?t=18048 oh and don't forget to use the search
joesouthgate Super Moderator Moderator Club Member Sep 24, 2008 #4 i meant uk micra callipers as they are a lot more common that JDM
Ed Fusion Motorsport MSC Founder Official MSC Trader Sep 24, 2008 #5 moddedmicra said: you would need k11 hubs iirc to fit the calipers. Click to expand... No you wont as it doesn't work...
curtis Ex. Club Member Sep 24, 2008 #6 Ed said: No you wont as it doesn't work... Click to expand... care to explain as the guide says it works if you replace the hubs
joesouthgate Super Moderator Moderator Club Member Sep 24, 2008 #7 Ed said: No you wont as it doesn't work... Click to expand... How come? Just wondering as Speedle says it works and he seems to have tried most of these things?
Ceirwan Ex. Club Member Sep 24, 2008 #8 Its the hub carriers you replace as well iirc? I hope this does work as i'm planning on doing it soon! :S
Arnold www.alanarnold.co.uk Moderator Site Supporter Sep 24, 2008 #9 Figaro brakes are vented right? You can use K10 hubs. I had March calipers and brembo disks, and i'm assuming March/ Figaro calipers are the same
Ed Fusion Motorsport MSC Founder Official MSC Trader Sep 24, 2008 #10 He didnt as far as I know try. But I do know someone who has tried and it didnt fit. iirc the lower wishbone is too different.
joesouthgate Super Moderator Moderator Club Member Sep 24, 2008 #11 i'm surew whipit talked about that he had done it aswell?
ollyc98 Ex. Club Member Sep 24, 2008 #12 Isn't it different for facelifts though? (you can fit k11 hubs on the facelift but not the prefacelift?)
frank Club Member Sep 24, 2008 #13 the rear-most wishbone rubber needs swopping, but i think the pre 98 1.0 hubs, wishbones and brakes will fit the k10
