hi all,
can someone explain to me brake fade?
i was messing with some hydro brakes and i can't see how it is possible...
i googled it and google says:
brake fade is where the brake fluid exceeds its boiling temp by excessive use, after boiling, bubbles form that can be compressed which means the pedel can move without applying any extra force to the pads...
as first i just excepted this to be true but then i thought, a brake system is completly sealed and full of 100% oil with no air. so there is no room for the oil to expand into. how can the oil form bubbles when it is already under pressure in a sealed enviroment?
basically you can't compress fluids but according to google if you heat the fluid and apply pressure then you can make it smaller... but in theory it should get bigger not smaller....
i'm sure i'm missing something, any petrol heads care to explain?
thanks
thanks
