Hi
@huttojb - May I pick your brains.
We have a more ‘mechanical’ issue.
Our 2008 Nissan Note has play between the steering wheel and the first universal joint.
ie I locked the rods etc that go from the back of the steering column assembly down to the floor - when I move the steering wheel there is play before it moves the spline at the other end of the assembly - it’s like it has a worn universal joint - but within the column assembly itself.
The electronic elements work fine!
Can you assist in explaining what the set up is between the steering wheel spline and the end spline.
ie wondering if I can get a (good) used unit and swap the electronics as such - or open and replace the offending worn bush (or whatever the assembly is within the column).
Much appreciated - Andy
