boyracergt
basicly got some wheels for the k10 that fit perfectly except for the centre bore . on the fronts the actual ring the disc and wheel sit on is shallow enough not to cause problems wheel goes on level. unfortunately on the back this part is deeper so i cant get them to fit is there a way to enlarge the wheels centre bore slightly?. also another problem is when the wheels on you can turn the wheel a couple of mm before it turns the rest of the hub. i thinks its where the studs are a lot narrower than the holes. even with the nuts tight its still moving. the standard steels also do this but when you tighten the nuts up it stops. the alloys seem to have inserts in the stud holes should i try the standard steel wheel nuts as opposed to the alloy wheel nuts im using? and is this ok as they have inserts? cheers
