Engine build
swsupermot
Club Member (Trial)
Need to squeeze a few ponies out of the super, only mods are full exhaust and induction kit, what's am I looking in terms of bhp per pound and what's the best. Budget about a grand.
1.0 pistons, 5 to 10 hp gain (dependent on other mods)
better inlet cam, 5 to 10 hp gain (ditto)
better exh cam 5 hp gain
If I was to gas flow the head a set of cams either a 1275 with 1.0 pistons or a 1.4 bottom end running a 50mm throttle and full exhaust. Lightened and balanced what bhp could I expect also what the save rev limit
Is it better to go for the 1.0 pistons in the 1.3 or go for the newer coil pack engine with more cc
you could go for a 1.0 coilpack block and pistons and a 1.4 crank and rods :wasntme:
(todays purchases :grinning: i,ll need to fit 2 headgaskets tho, the pistons stick out the top of the block :eek: )
