OBSERVATIONS TO SAVE FUEL
raise your vision UP higher (horison, over the trees, whats happening many cars infrot, lamposts, hdgerows, telegraph poles etc and keep moving betweendiferent distant and close spots consistently.....
you will build a bigger picture of what is changing and by how much....
the result will be less 'dabs' on the brakes....and less 'on and off' of the throttle.....
...smooth and subtle throttle control will pay you back in fuel consumption
GEARS TO SAVE FUEL
try to avoid revving the tits off the engine routinely
also try to avoid to HIGH of a gear.......
4th in a 30mph zome will use more fule than 3rd if you need 'response'
(squeezing the throttle in 4th will pump fuel but will not result in a decent change in speed.....but if in 3rd.....only a slight throttle adjustment will pick the speed up but without pumping fuel (carburettor prrgression enrichment)
MAINTENANCE TO SAVE FUEL:
good ignition, fueling (filters & settings), oil and the rest will zip you arround for less
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
