Driveshaft wont pull out.
No gd :( name things tht need removing for block n box seperating plz
all the bolts on front gearbox and rear of the box and drive shaft bolts 27mm on wheel hub, the gearlinkage bolt, there is more bolts on the rear mount of engine and box, it is easy job but hard to see the bolts so go under the car and u will see 3 tight ones on the mounts
You dont really need that metal plate between engine and gearbox... I'v ran for years without as has @frank.
I think it might be good for rally type scenarios. The possibility off foreign objects and all that. I don't bother running one still.
Very true SirChris, i found enough mud and water inside the flywheel housing on the rallycar with it in place dread to think what it would be like without!
Yeah with road use I wouldn't. I will with 700 odd quids worth of clutch going in at mid year. I am thinking of returning the sandwich plate to my setup. The water and various bits and bobs getting in here cannot be good for any clutch really
