Cylinder walls ok?
There is probably a lip at the top of the bores where the top ring doesn't reach the top of the bore which will allow you to roughly assess wear, after that I'd get a machinist to check size, taper, and concentricity if these are out of spec then a bore and hone, if not a hone and you could reuse your pistons, depending on your plans.
