finally got me new cylinder head last friday, thank you much james
all nice n flat n shiny but i noticed alot of grease packed in there (can't be too good during startup) and some hair n debris so it had to be overhauled.
i stripped all the cam shells n cam followers till this one puts up a fight. won't budge off easily so eventually mole gripped the edge lip n yanked it out, replaced it with the older follower.
inspection tells me the follower bore is slightly oval as if one side was bashed in hard
valves r out and loadsa grease there
better
i caught this odd crack in the exhaust follower bore nearest the dizzy, eek
heads all assembled n oiled
bolted in
when assemblin the timing chain i had a right rant all night with this mutha piece of metal preventin the chain hooking onto the idle sprocket without brute force (lotsa swearing)
putting in the temp sensors i noticed this hole that's not on my original head
ah bummer
engine's almost fin
tday i looked for a simple M16 threaded brass stop-end at the local diy shop to plug that hole but they only had this 15mm-12mm converter and a 15mm end-cap, bah, ok might as well try it
a thing i noticed bout the cooling system is that partco had prob given me the wrong thermostat cos its missin a bloomin small return valve found on the original themo, hence cos the system is completely sealed when cold, fillin at the radiator cap wont work cos air has nowhere to go so i had to pull out the heater matrix top pipe in order to fill the system
i put in the rad and the beam panel over it but noticed somethings very wrong, the top beam panel is totally misaligned to the left by 5mm, eay?
behind the front crossmember i found massive rust bucket and the crossmember panel near the rad mount has buckled a little hence may have moved the rad mounts, so this front chassis def needs changing asap
hooked everything up, started it with no sparkplugs to check nothings bashing, then tested compressions but all chambers showed ZERO pressure!?
30secs later i slap me forehead as i realise that the new cam shims james put in were much thicker or too thick than me older thinner ones, therefore the valves r not closing properly. DOH! lucky the valves n pistons werent fighting each other
soooooo
i guess i hav to take back off the cam sprockets, bearin caps, cams, followers & new shims before puttin the old uns back in
will be a long week...:down:
