Cutting out when Warm
this is where a narrowband a/f/r gauge is mega useful for diagnosis, using it to check the engine is coldsart enriching and closed looping properly and checking if it goes off the scale lean or rich when the judder occurs etc
Narrowband does have some uses then frank, generally the opinion seems to be that narrowband is the devils work!! :p
they do seem to be reviled eh ade :confused: but the ecu uses those very same signals from the lambda to regulate the fueling for 90% of the time, and to pass emissions tests
Just remembered I've a multimeter in my glovebox!
Any simple quick checks I can do?
Might have to boot Windows and fire up AutoData
yes you can do a resistance check scott (it should read 2500 ohms when cold, and 300 ohms when hot), or else tap into the lambda signal eh
Shall do it later :)
Just driven to work (15miles) with the 2pin sensor unplugged.
Cold idle was good, around 1,500rpm which gradually dropped the further I drove.
Pulling in 1st is okay.
Pulling at low revs is a little boggy.
Warm idle was around 750, little splutters at some lights but never cut out.
Revs are still sticking to 1,000 for about 5 secs before dropping??
Just as a totally different angle of it... is your fuel pressure regulator ok?
I still believe its the coolant sensor at fault but could be worth a quick look? :)
Revs will stick for a few seconds because of it overfueling iirc
sounds to me like you,re getting mad leanouts scott, and running on constant coldstart (unplugged) is just masking the problem.
if the a/f/r goes leaner than 20:1 ish you get a sharp missfire/judder, like a sparkcut/dizzy problem.
or is the judder a soft missfire/judder, like its over-rich/8 stroking ?.
and its juddering on all 4 cylinders ?
Bad injector? Fuel pump?
Couldn't tell you the type of misfire as I'm not an expert.
All I can say is it juddered more with the sensor plugged in.
I'll need to hunt for somewith with an AFR gauge :/
a duff injector will only affect 1 cyl eh mate, it might be the lamba ? if the ecu is,nt getting lambda signals it probably drifts into very lean conditions at certain throttle positions.
you can test the lambda signals with the multimeter on the dash like on some of my youtube vids eh :)
The lamda isn't too old, but it isn't a genuine Nissan/Bosch on either! Cheap eBay jobby..
I'll probe the signal wire when cold and warm and note the resistances/voltages
Good news. My throttle body should arrive at home today.
So I'll fit that if I have the time. I'll also fit the coolan sensor and I'll try unplugging the lambda. I've run without a lamda before (seemingly) without a problem.
Years ago I had a Honda prelude, that used to cut out when warm. The garage eventually found one of the fuses was separating when warm!!! don't know which one. they changed them and everything was fine for years...maybe ????
Well car has cut out just as I parked at home. Refuses to start. Going to get the top chain cover off to see wtf is going on.
Does this look right?:rolleyes:
Timing tensioner fitted, engine starts and runs fine.
Plugged the coolant sensor back in bug the eml light and fan are still on?
And it's also idling between 1500-2000rpm?
Okay, tensioner fitted, coolant sensor properly connected :oops:
Here's how she sounds now. Still not perfect but a million times better to the previous video!
The chain bouncing about like that and no tension it could have very likely skipped a tooth. Or you have chain stretch
Not say timing is your issue but its does sound like it
Yes! Thats what I meant. Curse my feeble brain.
Could the timing have been set on a slack chain? Otherwise theres idle adjustment valve on the tb probably
I can't remember if I dicked about with the throttle cable or wiggled the waxstat mec when I was trying to "diagose" my problem.
I could adjust the idle screw but that might just mask a problem? Though I've had no issues when driving to work other than a high idle
Revs to 2000 then drops to 1500. Cold start was 1500 bang on
Easy way to tell is leave it idling when the fan kicks in if it adjusts idle ok then its fine. If it has a bit of a fit then yea its poorly :)
its easy to trap the O ring at the bottom of the i/c/v scott (package en route btw :) )
Sweet.
I'll whip that off later and check.
I was tugging at the waxstat plunger, not sure if I could have moved it forcing idle open.
Hello bud. From your last line, that's exactly what mine was doing when I first got her, changed the TB and away I went....no more problems:)
TB is coolant heated? I can just clamp the hoses with mole grips and simply unplug and swap over?
