Baz
I'm just curious too read a few comments on how much you reckon my car is worth(not selling just yet)
Here' s all the info:
1989 Nissan March Super Turbo
Imported in August 2006
1989, Black
930cc SOHC 8valve 4cylinder
Twin Charged (Supercharged + Turbocharged)
90,000 kms
Timing Belt changed at 52k and recently at 89k
Full service also done at 89k . . . plugs, Oil and filter change and Blitz air filter, Original Nissan plug leads and distributor cap, also bypass valve replaced (Controls changeover from the Supercharger to Turbo)and all perished vacuum hoses replaced
LSD gearbox is factory fitted
110bhp factory standard
Standard boost is 0.9bar supercharger and 0.9bar turbo
Modifications:
Full Stainless steel powerflow exhaust (Cat back) Fitted by JON Exhausts Newry Northern Ireland
Blitz Starlet Turbo Air filter
Bailey Dump valve
Blitz boost Controller (set to 1bar on the turbo)
Blitz Boost gauge
Apexi Turbo Timer
Greddy E-manage blue ECU
Sard 235litre/hour fuel pump,sard adjustable fuel pressure regulator and fuel pressure guage
Endless performance brake pads front and drilled and grooved discs
Parts that came with the car:
Original front and rear dampers (still perfect condition)
Nismo Competition dampers 4point adjustable
Wheels:
5zigen 14” white Beckett N1R’s
Engine is mint not burning oil and not using water
Also spares available St gearbox,head,etc
1989, Black
90,000 kms
Modifications:
Bailey Dump valve
Blitz Boost gauge
Apexi Turbo Timer
Wheels:
