I will use bullet points to describe this one: I am so miffed that all I can do is laugh!!!
1. Slowly loosing coolant since 3 weeks ago
2. Tracked it to a porous heater matrix hose (was venting steam after stopping HISSSSS)
3. Fitted replacement hoses from the subs-bench micra (15 minutes)
4. Fired her up to temp and noticed the radiator was dripping (yes, leaking through corrosion ) too PAH!
5. Pinched the decent radiator out of the subs-bench micra snapping both radiator retaining bolts in the meantime (stubs stuck in the chassis of the main micra)
4 Deep breaths
5. Drilled out the snapped bits and fitted the decent radiator (knocked a flake of corrosion off of the engine block steel water pipe…..”not to worry”…well that’s what I thought)
6. While filling up the coolant again I heard a trickling noise????
Only to discover THIS....
.mov included for those of you with quicktime power….check this for added crippling effect
MOVIE:
http://www.roadar-northeast.co.uk/K10/100_3817.MOV
4 Deep breaths
MOVIE:
