coolant overfill
Me again..
Had car serviced today. At the time was told all fluids were topped up (topped up - nothing was needed. I popped the bonnet the day before and checked all was ok - well what I am able to tell what is ok). Anyway the coolant in the expansion bottle was at max (when cold). reason I check that because I had a leaking bottle once and had to be replaced. Well when I got home... I checked - they had only filled it way past the max line. I know the coolant expands when hot but from previous times when noticing - the level comes up to above half day in the bottle but now right at the top - and not sure if any had "squeezed" out.
I now the max line on the K12 cannot be clearly seen but surely a nissan/micra technician should have known that it didn't need filling up anymore. ARGHHH. If I dont do something about it will be cause problems.
Thank you
Write your reply...
