Just be aware stands and garage jack like I have come cheap. Look for stands that are certified and not cast iron but welded trough. Be aware some Micra's don't like stands on the rear sils (gives quite unrepearable dents), use it's rear axle in a lower stand setting. Be warned that included jack is for spare tyre *only* and putting your leg under a brake drum or whatever with such a jack is not smart. Also don't let it sit overnight, I can't find the pictures from it but it *does* give up put your car three wheeled non movable. The garage jack I have there is 12 kilograms aluminium costed me 105 coins and a long search. If you use stands, use it's guide pins and shake the car to be confident car can't drop on you (you might die or have permanent injury) and one option is buying a low priced very old garage jack in the size I have there but it will be iron and be 40 kilograms. I reckon 50 coins is fair enough, maybe cheaper, that depends. Also SAFETY FIRST. Those stands welded trough costed me 30 coins (all four and certified) second hand (never used before, no paint scratch). Cast iron stand is not safe, those will give up and let the car slide off. Also a leveled floor is what stands are certified for. On the street like I did and do, m8 be sure it can't trip. Really. You can have it for 135 coins (new) though like I did. This needs some effort. I hope I triggered you. If you need some assistance just ask, just ask. One more time, *don't* use spare tyre jack for other work, make sure car can't tip off (always and ever with what you have there), don't let car sit on spare tyre jack (lookup it's strength, it's a mere 600 kilograms and micra can be like 1200) and use two stands, or four stands, not just one. Be very confident on non leveled roads. If you need a pipe to get something loose, *no body parts under car* ever.
