Constant Blue Smoke
Paul Smith
Site Supporter
Ok a bit miffed now, she is back together modified the air box slightly fitted it all nice tight started her runs, revs and idles like a dream.
Now the nightmare - She is blowing dirty dark smoke which i kind of expected as she is running rich, but she is also blowing the dreaded blue smoke. I thought it'd burn off as we put a dribble with the pistons as you do to stop any scoring on the initial start up but its not clearing. I have tried a few times now including tonight where I stood out there for about 30 mins gently easing her up to arround 3.5k rpm but it showed no sign of letting up. Any suggestions as I'm at the stage where I really do not want to take the engine apart again GRRRRRRRRRRRRRRRRRRR.
I damaged a piston years ago and as a result it blew smoke but some how doesn't seem the same as now. As for valve stem sills i had a very expensive proffessional company put the head together for me so this sort of thing wouldn't happen (normally I'd do it)
:down:
the pistons didn't leak before, so not sure what would have made them go this time.
Is it possible the piston ring is sticking?
Its the one that came off rebuilt, hopeing its not a stem seal (if you iknow what i mean)
I'll check the plugs when i get home but they are brand new. Could over fueling cause this? Maybe fuel washing the oil off the bore and burning explaining the dirty and blue smoke.???
wishful thinking paul :wasntme: did you scrape any carbon off the tops of the pistons ?
Its possible I was careful even used a tac cloth but its not perfect so it is possible maybe need to find something to dissolve it ???
the pistons are tapered eh paul (.6mm smaller at the crown) so they will collect a lot of debris :eek:
if the valvestems/inlet tracts are,nt wet with oil, my money would,nt be on the valveseals personally.
cant you borrow a bore-scope to view the pistontops for oil puddles ?
is this a skimmed head paul ? because a big hike in c/r can make previously worn (but servicable) rings far worse at sealing :eek:
Yep she is a skimmed head thats a worry, although the piston looked in good shape but its hard to tell
most of the cg,s i,ve stripped had very congealed oil control rings paul , this current one was 2 coilpack ones made into 1 and were really bad (totally stuck fast into the groove :eek:) but once cleaned and restretched they,ve proved to be a very tight seal (even at 12:1 c/r)
Sorry been away But I actually agree with all Franks suggestions, I don't feel its going to be great news though, oh Dear mate, Hope it turns out to be something simple, You are due some good luck surely, keep us posted on this mate.
Hope all goes well Paul, wouldn't be nice to have to strip down but a problem found is a problem solved. Makes me thankful of making the choice to opt for a bottom end rebuild with new rings and ultrasonically cleaned pistons....we still have to see what condition all the bearings are in though :eek:
I have done a compression test and tried a few different setups.
Cyl 1 - 17 psi
Cyl 2 - 17 psi
Cyl 3 - 17 psi
Cyl 4 - 17.5 psi
I swapped the plugs out for some others i had around which were bosch super 4's and as a result the smoke has all but a very tiny occassional amount cleared. I believe the last plugs which were NGK BCP7ES plugs are breaking down and are running to hot. What I need to do is decide what plugs i am going to need and purchase those.:grinning:
It depends on the compression ratio and choice of cam but 17psi sure isn't right. I'm assuming you have read in bars and have increased the compression a fair bit with the skim, (Frank would know by how much), but if you're around the 12:1 mark then the figures seem reasonable...
