COMPLETE Turbo kit for sale
Status
Not open for further replies.
Davey C
Fortunately for you lot I no longer have a Micra…
SOoooooo!!!
I now have a FULL turbo kit for sale.
This is basically bolt on and go. (obviously you need a map too but I’m sure ed can sort you out no bother). This includes everything you need to have a turbo micra and there are a few options as you will see.
The kit comprises of…
A choice of Two turbos
Turbo Garret GT25
Or Garret T2 fully refurbed with 360 degree thrust bearing
And then…
Braided oil feed/return, and water cooled
Intercooler Custom front mount intercooler (inc piping)
Manifold HKS cast manifold
From the Nissan Cube bolt on kit
Engine management Greddy E-manage
Injector harness
Ignition harness
Pressure sensor
Fuelling Custom fuel rail with SR20 injectors
Blow off valve Bailey Twin Piston type, atmospheric dump valve
Actuator custom Turbo techniques actuator
Hosing Samco – Blue all that is required to connect IC piping
Air filter K&N generic cone filter
You can additionally have some of this too…
Engine management Hawk ECU with Micra turbo map
All looms included plus mapping disks
Fuelling Adjustable fuel regulator
If you want to swap some out from the above
And if you want to go really crazy and have the ultimate Micra Turbo then I can also provide…
Pistons JE low comp pistons 8:1 ratio
Rods Custom High strength standard length rods
(suitable for N/A as well as turbo)
Oil cooler kit Mocal 19 fin rad with Micra sandwich plate
Here are some pictures of the goodies, please ask if you want any more details.
Dave
IC Piping with Blow off valve (Bailey Twin Piston)
Engine Management
Emanage Harness
Modified SR20 fuel Rail with SR20 injectors
Adjustable fuel Reg
Front mount Intercooler
Stainless Intercooler Piping
Intercooler Piping with K&N
http://www.moddedmicras.co.uk/upload/files/4-K&N_airfilter.jpg
Hybrid T2 Turbo with 360degree thrust bearing, HKS Log manifold and Turbo Techniques Actuator
Or GT25R Turbo with 10psi actuator
52mm AFR Gauge
52mm Boost Gauge
Oil Catch Can
This is truly an excellent opportunity to make you Micra truly unique. From one enthusiast to another I will offer a good price but bear in mind how much all of this kit would cost you if you bought it separately before making an offer. The time, effort and haste saved is worth a fortune in all honesty. And then to know that this kit fits 100%, you will not have to spend a fortune on labour getting someone else to fabricate a kit and all the custom pieces, you can basically do it yourself on your drive with this kit. You are not likely to get this kind of opportunity too often.
Early Christmas Present to yourself???
Dave
Anyone interested in this as a low boost turbo deal,
6/7psi and most likely 130-140bhp...
Turbo ------------------- Garret T2 fully refurbed with 360 degree thrust bearing
Intercooler -------------- Custom front mount intercooler (inc silicon hoses and stainless piping)
Manifold ----------------- HKS cast manifold (Nissan Cube bolt on kit)
Engine management ----- Greddy E-manage
------------------------- Injector harness
------------------------- Ignition harness
------------------------- Pressure sensor
Fuelling ----------------- Custom fuel rail with SR20 injectors
Fuelling ----------------- Malsappi or FSE Adjustable fuel regulator
Blow off valve ----------- Bailey Twin Piston type, atmospheric dump valve
Actuator ---------------- Custom Turbo techniques actuator
Hosing Samco ----------- Blue all that is required to connect IC piping
Air filter ----------------- K&N generic cone filter
Plus a boost gauge, ill chuck that in to get you up and running too
£995
are you feeling a little sore?.....
sorry dude, but its too good an offer to pass up...
ill let you have a ride...
I didnt pass up on the offer, that was a problem.
There was a breakdown in communication (wrong phonenumber) so I didnt hear anything all weekend after waiting for payment details!
Not to worry, I'm putting something together with Craig ;)
One question though, why the need for the emanage?
as its there, its got the correct wiring, and its been proven to work......and its included in the kit..lol
no probs dude, so sorry i feel guilty.
well lets hope craig sorts you out... has done the business with me.. (twice in fact..) oo er..lol
yeah i got quite a few bits left, let me know what you are interested in and ill give you a price (email me)
Dave
think i found your e-mail sent it to y7our hotmail account i think. did you get it?
GT25R turbo,
Mocal Oil cooler kit,
malsappi fuel reg,
second inline fuel pump,
HAWK ecu (inc harness and disks),
there are bound to be more bits too,
SOoooooo!!!
Turbo Garret GT25
And then…
Injector harness
Ignition harness
Pressure sensor
Dave
Engine Management
Emanage Harness
Adjustable fuel Reg
52mm AFR Gauge
52mm Boost Gauge
Oil Catch Can
Dave
Hi mate, how much? Send me a message [email protected]
Status
