There should be a conector behind the centre console for it, you could just go to a scrap yard and get the whole unit. If all the wiring is complete will be a fairly easy install.
Theres two one for the light up surround and one for the actual lighter element...in not 100% on this but i think both are a spade type...and the plug for the light up surround should be spliced in about 2-3cm down from the lighter element plug, if im remembering correctly. (hope that makes sense).
