Hi,
Im attempting to fit my cigerette lighter(from halfords) into my k11.
Theres already a hole in the front panel and also a fuse in the fusebox for it.
Following instructions from http://www.micra.org.uk/threads/3766-cigarette-lighter , I dicovered the black cable in the pic below.
Is this the right cable? The reason I ask is that the cable is labelled(if you look closely):
- Amp
12
I have checked that the fuse is 15 amps but a bit confused as to why the cable says Amp 12. (there isnt even a 12amp fuse in the box)
Am I reading this wrong?
Also if this is the right cable, do i just connect it to the lighter unit and thats it?
Also do I need to diconnect my battery and the fuse before making this connection?
Please help
- Amp
12
Please help
