Checking and setting ignition timing, guide or pictures anyone?
Seb_
Give me some frogs.
Site Supporter
Hi everybody
yesterday I was chating with Baguete about my high fuel consumption on my 1.0, even if I have new oil, new filters, serviced TBody. I do about 9L for 100KM, even for city driving, it's a bit too much.
So he explained me I may have to check my ignition timing, that it was not that difficult
As a mechanical newbie, I've checked around the internet to read about it, so I will need a timing light gun, but apart of this fwn
Does someone here can write a little guide, or even take pictures of what I've to check, to set etc ? It would be much appreciated
Thank you
Seb
Hi everybody
Thank you
Seb
X2 need to look at mine when i do a service soon! Thanks for bringing this up Seb! :D
Very nice link euro ! I've been searching for this kind of guide on the primeras forums, but it was in the member only section (like our guide section on MSC). Now I have to read it a dozen times to understand it :p
Scott : I still didnt had time to go to the post office and wait in the queue, but i'm off friday, I will give it a go and let you know thank you ;)
Watch this video from 1:50 the explanations of the guys are quite clear!
I've never actually had to set timing but this video explains it perfectly :) :
Yeah I watched this a few times when you suggested it. It really seems to hurt my brain
Sent from my Galaxy Nexus using Tapatalk 2
You can also use a laptop+consult cable, to make the process easier!
Pick up a cheap Nissan Consult cable from ebay or forum market.
A Serial-USB cable is helpful :)
Then, download the free Conzult software, turn it on, set it into timing/idle mode! Presto!
No more need rev engine/restart -> disconnect TPS etc..
This is for pre coilpack K11's! Newer ones use the OBD2 interface
