Why wouldn't you be able to?could i use almera flexi? will have whole donor car so the more of it i use the more moneys worth i get
sure, just join the pipes under the driveshaft eh, or else buy a £74 stainless steel 4/2/1 mani (+ the usa shipping costscould i use almera flexi? will have whole donor car so the more of it i use the more moneys worth i get
the cone fitting at the bottom of the 1st cat, with the spring loaded bolts is the flex joint joeThere's no flexing bit on a stock cg exhaust is there? Why would you need it for the new one if engine movement is the same?
