Anything is possible provided your pockets are deep enough.Yeah well I removed a intercooler from a subaru and i saw the tt setup and was wondering id the same can be used or sorta used. With a cut off valve and everything.
Well im not to sure im new to the whole turbo game but both came off the subaru legacy. VF27 and i think TDO4 IHI turbos. Hense why im here asking for help hahabi-turbo arno ? or compound ?
Mmm ok sounds like a plan. But in regards to engine manigement what would you suggest ? If i take the throtlebody and injectors + rail. Would i use the primere ecu? Will it fit ? Or what other options are available ?they are big turbo,s for a 1.0 engine ! my original TD04 (16g iirc) would muster about 10psi on the CG13 and the TD05 about 7 psi (both at full chat)
and i tried the TD04 on a CG10 for a while, but i had to rev the nuts off it to get any boost
my advice would be to go for something smaller personally, and smaller still if you want to bi-turbo it
1992.what year k11 mate ?
there will be some info on the nistune site for those early ecu,s1992.
Ok what would you suggest i upgarde engine wise ?there will be some info on the nistune site for those early ecu,s
You reccon i can get 2 on there haha ?for twin or bi-turbo ideas, look at suzuki cappucinos. their engine is a 770cc turbo.
Not the best metal to rust ratio eitherno doubt! but cappucinos are still pretty expensive...
Haha thans for the reply guys so what would you suggest ia the best option i guess ?no doubt! but cappucinos are still pretty expensive...
