Tap the sump and return the oil feed to the sump.
Does anyone actually have any pressure readings for that plug as it's in a great place for a convo.
Craig
The most common method is to take a T from the oil pressure switch and use that to feed the turbo.
Yeah ill be moving it to my brothers garage soon, as i dont fancy working on the road! I have a t25 with a wastegate,front mount R33 GTs intercooler, and not enough pipe. ill be posting pics too, as it progresses.
I have had bad experiences with this method on B16 honda engines. i.e. crackingand breaking due to engine vibration. Me thinks ill be using a sandwich for higher flow rate and decent pressure.
That would only happen if you put too much weight on the thread. The right way to do it would be to mount the distribution block away from the engine on a second bit of pipe.
http://www.nengun.com/nismo/gt-lsd-mechanical-lsd
sandwich plates and oil coolers from hks for the micra...
Are you putting the sandwich plate between the block and the head? Think about any additional stress it will cause on the chain.
WTF! No its going between the oil filter and block. That is if i can find one. Oh and a turbo manifold. Saves me from finding pipes, cutting flanges and welding!
I have heard of people doing it like that believe it or not.
cheef
will you be making any other k11 parts (ie boot spoiler) ?
cheef
i,ll swop you my super s spoiler for a lightweight copy ? :laugh:
then you could join as a buy n sell member and knock a few up
