I'm having a problem with my wiring loom (Micra engine going into a Mini and I'm using the Micra loom). My engine and loom are from a Mystique so have all the toys, most of which I don't need!
I do want to keep the central locking but I am struggling trying to work out the wiring to the two modules in the photo. The smaller one looks like a "keyless entry" unit so I presume the signal from the key is sent there to unlock the doors and then the second (larger) module?
The wiring to the large connector on the large module stacks up with the Heynes manual diagram. All the heavy wires to the lock motors are there. However, I can find no reference to the keyless module or the wiring to the smaller connector. for example - I have a light green and a brown wire going to the ignition switch. Wires going to interior lights.
It looks like the larger unit is possibly Central locking and also interior light module? I'm worried there is a NATS connection in here somewhere!
Anyone have any info or a wiring diagram for this setup?
