I think battery is drained how can I sort this?
easy as pie...open both bonnets....put the red lead on both the positive bits on the battery and then black lead on both the negatives...then start the engine with the good battery. and then go and start ur engine...then disconect the elads and leave ur engine running for a bit
thats wrong one black goes on the negetive the other bit goes on a metal bit in the engine bay to earth a the car
bump it?
well its been on charge all night and sparks on the connector bit but still wont start. although it ticks over any idea what it could be? Its on charge whilst im at work a good 9 hours more
there,s a distinct lack of info there
I think his repeated attempts at starting the car, i.e keep on cranking it, drained his battery, so he recharged it and tried again and I think thye same thing has happened again, so he now needs to recharge again his batterey and look for other causes why it won't start. like fuel, pump, spark, sensors etc etc.
i agree, but it,s taken 30 posts to get to this stage *bangs head against wall again*
Alfonze, i really think you could do alot more to help people help you! lots of people are going to the effort of helping you, but you dont seem that ready to do what people say.
first: check to make sure there is a spark at the plugs (take a plug out, connect it to the HT lead again, then hold the end of the plug against somthing grounded, maybe the rocker cover?... try to start the engine and look to see if there is a spark, simple).
then come back and tell us what you have learnt.
otherwise, take it to a garage and they will sort it for you im sure.
forget it it starts now. Thanks for the help
petrol
petrol
