hi i want to install bike carbs to my micra cg10de n was 1dering if i can still use the dizzy or if not how would i convert n bin the dizzy??? plz help
it should work in a fashion, but i doubt you will have any vacuum advance (aka, load retard) it you dont rig up the maf and t/p/s signal inputs too (and you will have only a basic "rpm/advance" curve)
as frank mentioned, there will be no vacuum advance.. so for example when using air conditioning: it will feel a bit heavy every time the compressor kicks in.
i suggest a dizzy conversion to go along with the carb conversion if you have ac installed in your car.
i did a dizzy conversion before using a 4ku dizzy with vacuum advancer. problem was the shop that did the machining work did the conversion in a rush that resulted oil leaking inside the dizzy.
