Enuo
Glorified Electrician
Taller 1st, 2nd and 3rd on 1.0 box so slightly closer ratiosmore a lower final drive ratio, than a closer ratio really mate (same clusters, different diff)
same flywheel thom, nissan machined a bit more off the 1.0 one thohmm, a micra from 1999 is a first facelift right?
Because yesterday i got a gearbox from a 1999 1.0, but the nismo clutch won't fit?
Weird thing is, with the nismo clutch there came a flywheel from a 1.3, but cant spot difference between a 1.0 and 1.3 flywheel..
Are you sure it's not for a superturbo or something?yeah, but i cant the the nismo clutch on the 1.0 gearbox haha
the engine and gearbox came out of the same 1999 micraAre you sure it's not for a superturbo or something?
there are only 2 types/sizes of g/box input spline thom, the smaller MA/k10 (and prefacelift CG10), and then the bigger CG/GA/QG/SR and superturbo onehmm dont know..
hope that it fits a regular 1.3 box.
then i'm just going to use a 1.3 instead of 1.0
is the nismo spline smaller thom ?
Would mean its for a superturbo gearbox no? Would make perfect sense.indeed, the spline in the friction plate is ?smaller?
the ST g/box is an RS5F31 eh andy (GA16 etc) that nismo clutch must be an RS5F41/180mm hybrid like mineWould mean its for a superturbo gearbox no? Would make perfect sense.
