Buying lowering springs, 30mm or 35mm??
S
siu16
Guest
Hi need some help on buying lowering springs for my k12E. I have two choices or either 30mm or 35mm? They will be lowered on 17" Rota alloys which are being refurbished right now. Does anyone have any pictures of k12's lered on 30mm 0r 35mm? Would be alot of help.
Thanks!:glance:
I'll second that. K12s are about 4 foot off the ground! Go as low as you can!
Just think about where you drive the car though! I've lowered both my Orion and Micra and now speed bumps are a mission for both!
35 mm should be no problem, oh and ollie my old mk4 escort was lowered 120mm on 60mm g max springs cut in half! and that sill went over speed bumps just a bit slowly!
