CMF_GTRHOLIC
» CMF MemberAs the title says, i want to build a ball tearing cg13. I dont want to turbocharge the engine as i dont really want to lose too much ecconomy. I dont have my cg13 yet nor my micra for that matter, but because of the cost of parts for these little cars, i am becomming more and more excited! compared to the rb26 theyre really cheap! i would like the input of fellow members as to what or why things should be done. If you could speak from personal experience that would be even better. for example, dont use a 4 inch exhaust on the micra because the wheels wouldnt touch the ground etc....
here are some of the things i have planned,
TOMEI PROCAMS
INTAKE 256DEG 8.35MM LIFT
EXHAUST 256DEG 8.35MM LIFT
(ANY OTHER SUGGESTIONS?) DO I NEED TO CHANGE SPRINGS AND RETAINERS? NOT MULHOLLAND CAMS COS I CANT GET THEM.
IMPUL EXHAUST MANIFOLD
Exhaust system
suggestions please! something not too loud!
Air filter kit (pod style)
Brands and reccomendations please
NISMO CLUTCH DISK AND COVER
JUN FLYWHEEL
JUN RETAINERS?
(IS IT NECESSARY?)
TOMEI METAL HEAD GASKET
ø72.7 BORE
0.7mm THICKNESS
GROMMET TYPE
OR
NISMO METAL HEAD GASKET
0.5 OR 0.6MM THICK
RECOMMENDATIONS PLEASE!
FORGED CONNECTING RODS
(DONT KNOW OF ANY JAPANESE TUNING HOUSES THAT MAKE THEM) CAN ANYONE SUGGEST SOMETHING LOCAL OR AMERICAN? PRICES? WHERE TO GET? NOT TOO EXPENSIVE PLEASE! IE CARILLO H-BEAM ARE OUT.
FORGED PISTONS
DOES ANYONE KNOW ANY LOCAL OR AMERICAN BRANDS? NOT TOO EXPENSIVE PLEASE. PRICES? WHERE TO GET? COSWORTH ARE OUT!
HEADWORK PORT AND POLISH (WHERE TO GO IN BRISSY/GOLD COAST AREA) HOW MUCH SHOULD I EXPECT TO PAY?
Also, do i need to do anything for the preparation of crank and block? Is o-ringing like ciscos engine necessary? (how much?)
FOR HANDLING,
Nismo s tune shocks or konis? how much for konis?
can someone suggest spring rates? RG kit is too dear!
Nismo stabilizer kit front and rear or whiteline? (how much for whiteline?)
Pulsar brakes n14sss (how much approximately?)
Nismo steering rack bush kit.
Nismo engine mounts
Nismo lower arm bar
Nismo panhard rod (rosejoint) or bush type
Nismo strengthened rubber bush kit (dont want nolathane)
c's quicshift kit
Thats all i can think of at the moment. of course there are visual enhancements eg body kit etc. but my mind seems to be changing a lot at the moment, and i cant seem to decide. although ive already started to buy the nismo body kit parts, i kinda really want to go flared overfenders. im open to suggestions though. does anyone know what a genuine front super s bar from nissan is worth? any kits that are made locally that are good in quality? as japanese kits are too expensive to ship!
TOMEI PROCAMS
Exhaust system
JUN FLYWHEEL
JUN RETAINERS?
(IS IT NECESSARY?)
ø72.7 BORE
0.7mm THICKNESS
GROMMET TYPE
OR
0.5 OR 0.6MM THICK
FORGED PISTONS
FOR HANDLING,
Nismo engine mounts
Nismo lower arm bar
c's quicshift kit
