Azzydot micra turbo build
that link you posted says m10 x 1 mate ^
frank this is what I got with the kit
Now I know I can be a little negative sometimes but this build is not going to end well if at all.
Azzy you say you've built turbo cars before yet you're constantly asking the most basic of questions. Wouldn't it be easier and safer if you just paid someone to do it for you?
Or at the very least do your research before asking a stupid question like "does b&q do bolts", just for reference it's a diy shop so yes they do nuts and bolts.
I've said that couple of time already. Glad I'm not the only one
Azzy please research stuff
I was right they do sell them and oil leaks fixed it was a m10 x1.5 so I got few if needed they tight fit, going to get my down pipe done now
this is gonna be one looooooong project :D ,
1/8 bspt thread in the head, and m10 x 1.5 thread in the turbo abdul
Frank I got thread bolt In engine in ok, soon as I reved it up it poped out the bolt for turbo feed line, turbo line to turbo is fine and don't come off its my engine bolt to feed line? Is that same m10 x1.5
sounds like you,ve stripped the thread dude ! pic,s would help us to understand what you mean
As in Franks post the head is 1/8bsps thread, if your using m10 x 1.5 its the wrong size
you cant mix threads abdul, it sounds like you need a 1/8 bsp to m10 x 1.25 male to male on 1 end, and an m10 x 1.25 to m10 x 1.5 male to male on the other end
I can see your post and like count shooting up in this thread frank.
Gonna be a long build for you ;)
so the thread I got is wrong ? so I need 1/8 bsp male to 1.25 xm10 male for feed line ?
it should be 1/8 bspt really mate (tapered thread) and we dont know if your pipe has swivel fittings (convex/concave)
you would have been better to use a pipe with banjo fittings really (like mine) so that you dont have thread leaking issues, and you only need 1 banjo bolt each end
