micra_pete
Steel forged fast road cams pair £595
Steel forged rally/race cams £695
fast road cams 248deg inlet and 238deg exhaust, with 8.50mm and 8.40mm lift respectively
Exchange ecu £495
Gas and oil top adjusting suspension kit £495
avanti i believe use the same method as myself for the ecu, it is not a piggy-back unit but a standard ecu with correct mapping
Exchange ecu £495
The ecu is programmed to go with cams depending on what profile you pick,
The chip changes the fuel and air mixture as set buy our company in Italy these chips were specialy designed for avanti,on Engines that we build for fast road rally and race They will not tell us the secret!!!!!
The unit have to be sent to Italy to be modified
Also we are design'ing compitition clutches wich will be avaliable eaily next year
Kind regards
Franc Rzzuti And Ed Antonello
