Hola had issues buying my replacement seals so sent to Nissan to get some. They couldn't get none so bought some from a seal specialist locally. I've put 2 different sets of seals in over a week period. Both leaked loads. The ones I fitted yesterday where 56 Outside diameter and 38 inside. These one pulled out of thr box and stayed on the shaft- was a bit much grease on outside of box where seal fitted. Does anyone know if the 1.0 shafts are 38 mm diameter? My 1.3 shafts are 40 mm diameter.
Does a 40mm shaft require a 40 mm internal diameter seal? I put 38 internal and feels quite snug but maybe too snug?
