Driveshaft oil seals
I will shortly be renewing the driveshafts on my '02 1.4. I've acquired the shafts and I'm happy undertaking the job, however it recommends also changing the driveshaft oil seals. I've no problem with that, my question is does anyone know where I might obtain the part number(s) or indeed the parts (ideally online or delivered in the uk). A few searches I've tried are unavailable, and I don't want to wait until I've stripped it out and measured the seal as the car is my only transport at the moment. Any and all advice appreciated.
After trawling past posts filtering info have found relevant numbers, and also potential suppliers, however due to current events none available. Will wait it out ...
if you don't disturb the seals much you could leave the originals.
do the swap and see if they leak.
if they do just drain the gear oil and swap seals when you get them
Write your reply...
