well the centre bore is very important, the wheel sits on the hub, the wheel nuts just hold it on sideways, if the centre bore is to big the studs could shear off and the wheel will come off. if it's too small it won't fit on the hub.
I find the Renault wheels are ok as they are only 1mm bigger.
If you get them too big you can get spigot rings that step the size up.
