another set of white dials on ebay
Yes they they can fit yours, depending on the year of your car/type of clocks you have i.e. digital or analogue. I have the pre-facelift clocks on my facelift model. As long as you have the analogue clocks which uses speedo cable I dont see the problem. Even if the wiring is different, they can be swapped around ;)
physically they will fit, but there would be alot of modification required, to the loom and also a cable speedo would need to be fitted and the electronic sender removed. the ECU may have to be modifided
