Igloo, do this if you can:
- Disconnect the RCA leads but have the amp wired up as normal, including the power/ground, REM cable, speaker cable, etc.
- Power on the headunit as usual, so that the amp turns on. Do you still get the noise and engine interference on acceleration?
Don't just assume its your new amp causing the problem.
Had enough of this, I've nearly wrecked things in the process.
I've had to replace some of the wiring clips due to taking them out so many times.
I've completely stripped everything out, and put it back in again. Next trip is going to be to a local audio shop and let them have the car.
