Amp
think of what mate there is no link or make put down depends on what amp it is and what are you putting it in to power a sub or speakers
Well it probably is worth its £35, if you ignore the fact the claims on it are utter ******!!!!
That amp will not even be 240watts peak let alone 1600. You could not sell that in a shop as it would be false advertising. I have the kit to measure power and there is nothing I could do no matter how I tried to fiddle it to make that amp even appear more than a few hundreds watts let alone 1000+
FYI I had an amp that did produce this power, It had 180A of fusing on it. This one has 20A....
i could but iv already got a good sub and itd b easier for me just to get an amp n wire it into that because then i can plug speakers into it aswell.
Avoid. One of my amps cost me £30 from Ebay and its a decent make (Kenwood)!
Edit: What do you actually want from the amp? By the sounds of it you want to run a sub plus some speakers, so ideally you need a 4-channel amp.
