You're at university....you should have learnt by now that you can't leave things until the last moment.
Uni is also totally different, it depends on you studying for your degree (i.e. "reading for your degree")!
If you'd popped into your library for an hour or so, you would have found quite a number of books on the subject, many of them under power/energy along with the automotive section.
Good luck with it, but try not to do it again!!!
Edit: If its a 2000 word essay you'll definitly need to quote sources, probably using Harvard referencing. So get down the library and read some books!
