Anto Modded
Is the almera 1.3 engine the same as the micra 1.3. Would it fit straight into a micra.
Anto Modded said:My father is a mechanic but i dont want to get into too mad a hassle to change if i can help it.
@James...ive only ever seen 1 micra with a 1.3 engine over here and it was a sr., i meant to say
james betley said:it would be 2 much hastle 2 do it but It can be done
Anto Modded said:I have a 1.0l and want something that is easy enough to fit and wont cost a fortune to do. 1.3 would be good but if a 1.6 could fit nearenough as handy it would be the better option
Arnold said:I was considering the 1.4, then someone said, you might aswell get the 1.6.. so when i started looking at that, people started saying, you may aswell buy the 2.0!!!
That would be the E13 then, can only manage 59bhpwilsonian said:the 1.3 engine out of the sunny isn't the CG13DE, I believe it's an older 8v model...
