Also rev limiter has been ordered...
He was a mate of mine and he really wanted a K10 spoiler and was going the scrap the ma12!!Engine for plastic......bargain
Probably a silly question... but that's meHe was a mate of mine and he really wanted a K10 spoiler and was going the scrap the ma12!!
Only using the MA12 until the end of show season then cg13 the car. Going to us cg13 loom, throttle body, ga16 airbox with my exhaust system. Should see me about 95hp which is what jamie had which is enough for the k10 and about what I am running at the moment.
some cars if you change the filter and exhaust you dont mate as modern ecus learn and change the settings themself after a few hundred miles. With the k11 ecu I really dont know but I bet a good remap with the setup would see some improvement but not worth the money.Probably a silly question... but that's me
Do you have to map it when you make changes like that to an N/A to see better gainz?
Oh really? well cg13 injectors it is. Well I can fit a wideband to the standard micra lambda just to give me a rough idea of the air/fuel. So we shall find out. I can see how it will piss everywhere.Ga16 injectors? Don't do it. Ignore what mario says, you'll just p*ss petrol out the exhaust and make less power.
depending on what fuel reg you runGa16 injectors? you'll just p*ss petrol out the exhaust and make less power.
Assuming stock eh, you'd have to run fairly low pressure to get the correct amount of fuel... would probably end up dribbling out the injectors and not mixing very welldepending on what fuel reg you run
i ran 293cc SR20 injectors with a stock ecu for most of 2012, GA ones are only 1/3rd bigger than stockAssuming stock eh, you'd have to run fairly low pressure to get the correct amount of fuel... would probably end up dribbling out the injectors and not mixing very well
re-drilling the turret is probably easier, but my bolts were shifted like that to keep it "looking stock" scotRight then I never delved into CORRECTLY fitting front coilovers before but I am going to use corsa top mounts with my corsa B front coilovers but they will be the same width as micra top mounts.
This is because I am going to mod the top mount. I am going to drill holes in the topmount the right width then put the bolts from the corsa mount through the new holes then tack weld them in place. This in my eyes will be more than suitable and much easier than what Enuo did also safer than the micra topmounts.
Awesome mate. I will see how mine turns out. I like the idea using the correct topmounts. After first hand using washers and other stupid methods to attatch coilovers which seems to be the norm on here. I dont fancy doing it again and rather using corsa top mounts and just move the bolts to the same width than the Micra ones. Seems so much easier.re-drilling the turret is probably easier, but my bolts were shifted like that to keep it "looking stock" scot
1 of the dutch guys is trying an alternative method
Cheers mate means alot. You method did seem a really good way.Or there is always my way front shocks are a bit tired (got them for free, twas to be expected) so when i replace them will give them a good inspection
here,s a pic of mine scott, just a 5 mm filed slot iirc, and re-weld the studs http://www.micra.org.uk/threads/corsa-b-coilovers-to-fit-micra-how-too.46092/page-4Looking at the top mounts in person what I plan to do seems very possible got a bit of still I am going to cut a reinforcement plate as well. Its starting to look like the simplest and safest way to do coilovers for micras...
You have done it as well good man! Your the only person who I know of which has done it them.here,s a pic of mine scott, just a 5 mm filed slot iirc, and re-weld the studs http://www.micra.org.uk/threads/corsa-b-coilovers-to-fit-micra-how-too.46092/page-4
Nah mate why?Cambering one wheel?
Top hole slotted on one shockNah mate why?
Sent from my GT-P5110 using Tapatalk 2
They are both slotted mate must be the camera angle.Top hole slotted on one shock
Want me to bring you your wire. Sorry dude.Modding the mounts today but i got no working welders!!!! Arrchh annoying. View attachment 30386
I hate using them day to day though mate. Rubs loads, whoever refurbished them did a crap job as well because the metal is rusting underneath the paint so got my money back from the refurb and I just want to shift them asap.I prefer the wellers
They look badass
Pretty sure there's no mention of that in your sale ad!whoever refurbished them did a crap job as well because the metal is rusting underneath the paint....I just want to shift them asap.
Thats the reason why I am not flogging them on here haha.Pretty sure there's no mention of that in your sale ad!
Yeah mate. They are what I say brand new. Did about 3 miles on my mates corsa.What corsa b's and how much? Mine are squeeking haha
What brand I meant haha and very tempting...Yeah mate. They are what I say brand new. Did about 3 miles on my mates corsa.
£50 they are yours mate.
They are fk mateWhat brand I meant haha and very tempting...
