L
ljames555
hi a neighbour just bought this car and wants me to fit stereo now i have had quick look.
i know it needs a earth ,and have a ford maverick iso plug only slight problem i see is fitting the cage because if you take the trim off there is no support above where the cage would go and the original radio sticks out abit. would i be right in thinking put trim back on then insert cage and bend pins around this ? will this be enough support ?
thanks in advance
thanks in advance
