Should fit fine and all speedos are the same buddy just the rev counter you may have a problem with.
There not all plug and play you may need to run a wire to the dizzy...Whats the prob with the rev counter?.
Do the 1.3s redline at the same as the 1.0s?
ah fair enough, mines was plug and play .
I assume the redline stays the same between the 1.3s and 1.0s aye?
I do believe so but frank or polly or any other guru on here will be able to help with thatah fair enough, mines was plug and play .
No, I've heard the 1.0 has a higher rev range
the 1.0 is capable of revving higher eh (shorter stroke)Hmm interesting, @frank
Clocks I got were from a 1.3 I believe and they redline at 6.5krpm
the limiter will kick in at about 6.9, but i bet it would stand 10k npAny idea to what RPM? as I said highest iv had it is 6.5 :L
Get an aftermarket bike tachometer and tell us what number it gets to before it pops?
Pops/explodes/detonates/violently self-dissasemblespops? .
pretty sure @IRNBROO had my car hit the limiter and the exhaust was popping
