went to a scrappers and bought a micra engine, having been told its a 1.0.... get home and its a 1.3, no use to me at all. if you want bits from it please make me an offer. i've got the following
block - £5, collection preferred.
lower timing chain with plastic tensioner/cover £12 posted
oil seal housing £10 posted
crankshaft £15 posted (heavier than the block)
crank pulley £10 posted
crankshaft bearing cap beam £10 posted
lower timing chain sprocket and spacer £10 posted
flywheel & fitting spacer £20 posted
pistons and con rods (i am not seperating these. its too much effort for me) £10 posted
sump £10 posted.
oil pick-up from sump, £10 posted
water pump £10 posted
i've extended this list since i've stripped the block.
sump £10 posted.
