1.3 engine bits
went to a scrappers and bought a micra engine, having been told its a 1.0.... get home and its a 1.3, no use to me at all. if you want bits from it please make me an offer. i've got the following
block - £5, collection preferred.
lower timing chain with plastic tensioner/cover £12 posted
oil seal housing £10 posted
crankshaft £15 posted (heavier than the block)
crank pulley £10 posted
crankshaft bearing cap beam £10 posted
lower timing chain sprocket and spacer £10 posted
flywheel & fitting spacer £20 posted
pistons and con rods (i am not seperating these. its too much effort for me) £10 posted
sump £10 posted.
oil pick-up from sump, £10 posted
water pump £10 posted
i've extended this list since i've stripped the block.
gtsnissanb: because ive already got a 1.3! wanted 1.0L pistons to make high compression motor
mark: not sure will have a look. you want the pistons as well as the rods?
No, just crank and rods, if you are able to separate the pistons. Could maybe do a swap for some 1L pistons :p
mark: i dont seem to be able to remove the gudgeon pin, so feel free to the pistons!
will: are the rods different lengths then? Mr. Haynes doesnt give that sort of information out. says the stroke is different, but i have presumed that the rods are the same and the crank is different.
Oh god i totally forgot about this... PM me your details and i'll paypal you some oney for cranks rods and pistons! So sorry!!
